iNet_forum_header_100112
Canon USA
Reply
New Contributor
Bernardo
Pixma mg6220
My pixma mg6220 is always showing error code c000.
I have detected why the printer head holder will not move. The problem is that the mechamism the engages the holder
stays up all the time. It is a small lever under the holder. The senser that controls the lever does work in order to allow the holder to move either in or out.
Any ideas on how to solve this problem?
Bernardo
Please use plain text.
Michael
Re: Pixma mg6220
Hello Bernardo.
This error may occur if one of the ink tanks was not seated properly or when there is a loose object stuck inside the printer.  Please try the following:
1.  With the cover of the printer open, unplug the power from the back of the printer or the wall.
2.  Look for any loose objects or packing material in the printer, clear if necessary.
3.  Try gently moving the ink tank holder as close to you as possible.  Try pushing the closest ink tank down.  Once clicked into place, try moving the ink tank holder closer, repeat as needed.  If you meet resistance, do not attempt to move the ink tank holder any further.
If the issue persists, please contact our support group using the "Contact Us" link below.
