iNet_forum_header_100112
Canon USA
Reply
New Contributor
rcollier6
How Connect MX452 to WiFi?
Have new MX452 and can't get it conne3cted to WiFi.
Please use plain text.
Michael
Re: How Connect MX452 to WiFi?
Hello rcollier6.
Please try the following steps to connect the unit to your Wi-Fi router:
1.  Press the Setup button on the printer.
2.  Use the arrow keys to select Drive Settings and press OK.
3.  Select LAN Settings and press OK.
4.  Choose Wireless LAN Setup and press OK.
5.  If a WPS prompt appears, press the STOP button.
6.  Select Standard Setup and press OK.
7.  Select your Access Point and press OK.  When entering the passphrase, use the Tone or Star (*) key to change character modes.
Once this has been done, insert the CD for the unit into your Windows or Mac OSX computer and perform the installation.
New Contributor
Walker017
When I try to connect this way, the printer is still not able to find the connection. Any other suggestions?
New Contributor
Bethany
Hi! I do not have the CD anymore for wireless set up for this specific printer. Is there a place to download this online?
Thanks!
New Contributor
ahayden
Mine disconnects and I can't get it back online... drives me crazy... there must be a way to correct this!
MarkII
Hi Bethany,
The drivers for your printer can be downloaded from our website.  CLICK HERE!
If you have any other questions, please feel free to Contact Us
New Contributor
pmpalma
sorry for the highjack
Is there a way to to connect a Windows 8.1 x64 machine to the MX452 without installing any special drivers and or program from Canaon? Trying to keep the install programs as low as possible.
I'm able to install the printer bt clicking find, add printer and following the promts, it gives me a wifi printer no problem, but as soon as I plug in the USB cable, it install me a new printer. Delete it, and as soon as I plug in the USB cable again, same thing... new printer. I worked well yesterday, but foolish me, deleted the printer and now, can't seem to make it work.
So, to sum it up.... trying to install the printer without the need to install Canon software, have one printer (yet, shows me printer and fax??) have it work but USB and WIFI without having two different printers.
It's driving me nuts... thx to all
New Contributor
ahayden
This worked for me but as soon as I keyed in the password the connection was reset and I was good to go! Now I keep the rounter password handy by the printer!
RUN
New Contributor
RUN
I tryed the way you suggested and I have the CD drive content downloaded in my Mac, but I still can not use the wireless priting. Would you please offer me a solution to that? Is there any limitation of the distance where I can use the wireless priting? Hope you could answer my questions. Thank you.
New Contributor
ddarren
Same issue.
I downloaded the driver again.  Installed, restarted the mac and the printer.
Still shows Printer not connected.  ARGHHHHHHHHHHHHH
