iNet_forum_header_100112
Canon USA
Reply
New Contributor
jdegann
Error message on my MX700 Printer: U052 This type of print head is incorrect.
I got this after installing new ink - it worked just a bit and then when I turned printer off and on, got this msg.  I took out cartridges and head, put them back in, and no change.
Please use plain text.
Michael
Re: Error message on my MX700 Printer: U052 This type of print head is incorrect.
Hello jdegann.
Please try the following to see if we can resolve this error:
1.  Open the cover of the printer.
2.  Remove all ink tanks from the printer.
3.  Lift up the gray locking lever on the side of the ink tank holder.
4.  Gently remove the print head from the carriage unit.
5.  Place the print head back in and lock the lever down.
6.  Place all of the ink tanks back in the printer.
7.  Close the cover and turn the printer off.
8.  Unplug the power from the printer.  Leave the power unplugged for about 5-10 minutes.
Once this has been done, plug the power back in and turn the printer on.  If the error persists, please contact our support group using the "Contact Us" link below for additional assistance with this matter.
New Contributor
RMS7575
I followed the procedures you listed below (twice) but still left with the U052 message.
Thanks in advance for your help.
Moderator
Jason
[ Edited ]
Hello RMS757!
If the error remains after following the procedure above, please click on the following "Contact Us" link so we can look into your service options - Contact Us.  Thanks so much!
lh
New Contributor
lh
That makes another
lh
New Contributor
lh
but the procedure worked
New Contributor
steelguy
I have tried it four times since I got the error.  No luck.  I hope this happen doesn't befall my MX860 as well.  I noticed that this seems to happen with a few models(based on other posts that I have read.)
New Contributor
choc1970
Having the same problem what a pain as need to print some papers off ! watch this space printer is off !!:smileysad:
New Contributor
choc1970
Help have done everything it says & still not working ?
Moderator
Stephen
Hi choc1970!
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, however we need to let you know that the Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please click here and select your country or region for your support needs.
Feel free to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
