iNet_forum_header_100112
Canon USA
Reply
New Contributor
kabtq9s
MG3100 wifi printer offline
My laptop keeps teling me that my MG3100 wifi printer is offline but its not. I have to restart laptop everytime I want to print something if I haven't printed something in the past two days or so.
Please use plain text.
Michael
Re: MG3100 wifi printer offline
Hello kabtq9s.
This issue may be related to a timeout between the router and the printer.  When this error occurs, we would have to advise that you power the printer off and back on or restart your computer in order to refresh the connection.
New Contributor
Davebste
When it says the printer is offline make sure you can still browse the internet or some other task that requires connectivity.  My laptop a month ago had a trojan and he was using the power settings to disable my wifi after he would change my settings and i would have to reboot to get it back online.  A simpler excuse on a laptop is the switch is inadvertantly being moved.
Just a thought.  When i have connectivity I first make sure i can connect to anything else.
New Contributor
Davebste
anytime you restore your computer from the disk it came from or any other OS disk make sure you have all updates after SP2 and update all Apple software and do not let the computer open the application till it has all its updates.  The trojan got in just after i had formatted my drive.  I had only installed my full subscription MacAfee, IE, Safari and iTunes.  By changing my SMTP settings i was able to get a trail.  When my email settings were correct he could send an email and remove traces of sending it but after i changed the SMTP his trojan didnt delete the errors left behind and i was thus able to track his method of entrance to a hole in iTunes.
New Contributor
Worcgg
This is exactly the problem I have had...everything seems to work well until there is a day or so I don't use the printer. Then I get the message that it is offline. I have the exact same printer at work and even over a weekend when I come back into the office I never have to turn it off and back on. This is an annoying problem. I did a firmware update, and still have the problem. The same MacBook computer was used to set both printers up. Please advise
Michael
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue.  Please contact our support group using the link below for additional assistance.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Occasional Contributor
Another_Victim
On 2014-10-06 I posted the details of the solution that worked for me at a similar Canon forum:
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/Mx920-Wireless-printing-problem/m-p/118...
It continues to work for me.  The wireless printer connection hasn't failed since then.
It's a permanent solution that you only need to do once. (It isn't a workaround that wakes the printer temporarily after its connection fails.)
The solution involves using your computer's web browser software to access the printer's built-in web server (by entering the printer's IPv4 address into the web browser's address field), going to the printer's Settings webpage, and entering a value in the Location property. (Which was blank by default.)
If you try it, please post (preferably in that other Canon forum) a few days afterward, to report whether it solved the problem.
Good luck!
