iNet_forum_header_100112
Canon USA
Reply
New Contributor
michaelzxu
MF8080 Printer scan driver problem on Mac Pro
I purchased a image class MF8080cw printer recently and downloaded the scan driver from Canon website.  I was able to print from my Mac Pro but not scan.  The print won't find the Mac, however, no problem to find two PC I have.  Anyone have a clue.  Thanks.  Michael.
Please use plain text.
New Contributor
michaelzxu
Re: MF8080 Printer scan driver problem on Mac Pro
When I select Printer & Scan from System Preferences and click Open scan, it will display an error msg stated:
Scanner reported an error
Cannot scan because of the following:
-Scan type set on the scanner is incorrect
-Scanner is busy
-Error occurred in the scanner
-Scanner is in Sleep mode
Check teh scanner status and try again.
Scanner driver will be terminated.
Error code: 2100010
I am sure Scanner is not busy, not in sleep mode, scan type is correct.  Not sure what error occurred.  Anyone know what should I do next?  Thanks.  Michael
Julius
Hi michaelzxu!
Are you setting the imageCLASS MF8080 for "Remote Scanner" mode, scanning from the operation panel on the front of the unit, or trying to scan from a computer?  If you're trying to scan directly from the operation panel on the front of the MF8080, are you able to scan after placing the unit in "Remote Scanner" mode and then pressing the SCAN button?
New Contributor
esco
I have same problem. I am tring to scan from mac and says same things. also when I click scan>pc1 on mf I can see pcs but I dont see my mac.(mf is in wireless mode on network)
New Contributor
esco
any reply?
New Contributor
paul74wong
I'm having the same problem too.  On the MF I have it in SCAN mode and selected "Remote Scanner" option, then on my Mac I go to Applications/Canon MF Utilities/MF Toolbox.  Once I launch the MF Tool  I immediately get "Cannot communicate with the selected scanner. The scanner may not be connected, or may be turned off" but obviously that is NOT the case.  So I hit "okay" then go to menu "MF Toolbox/Networking Scanner Settings.." from there a new window "Network Scanner" will pop up and I click the plus sign to add the MF Scanner.  Another window "Add Network Scanner" will pop up and I'll see the printer in the Bonjour Name field.  I then select the "Canon MF8000C Series" and it will start to search for ibut in the MAC Address field I'll get "Could not acquire".  I then tried inputting the MAC Address manually through the ip Address option in the Network Scanner field but still no luck.  I'm going to continue experimenting with this before I contact Canon tomorrow.  Great multiprinter but really complicated for no reason.
