iNet_forum_header_100112
Canon USA
Reply
New Contributor
mleesmail
What is error code C000 on my MX870 printer mean? How can I fix it?
Please use plain text.
Frequent Contributor
Devin
Re: What is error code C000 on my MX870 printer mean? How can I fix it?
Hi mleesmail,
This error indicates that an internal error has occurred which may be resolved by resetting the printer.  Please follow these steps for isolating and resetting the printer:
1.  Open the printer's front cover, and then open and close the print head lock lever (do not remove the print head).
2.  Make sure all ink tanks are seated properly.
3.  Make sure all packing materials have been removed.
4.  Make sure no paper is jammed in the printer.
5.  Disconnect the printer cable from the printer.
6.  Close the front cover and turn the printer off.
7.  Unplug the printer from the power source, and then plug it back in after five minutes.
8.  Power on the printer.
If the error returns, the printer will require service options.   Please contact a technical support representative who can provide you with your service options.  They can be reached by calling 1-800-652-2666 between the hours of 10AM and 10PM EST, Monday through Friday.
